350 - 383 worth it? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-25-2012, 05:51 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Originally Posted by s10mannn
ok so i think i got it straight, ill be using a 3.750 stroke crank with 5.700 length rods and 383 pistons with 9.5-1 compression and a .060" bore sound good ? ? ?
Im obviously still pretty new to this but i appreciate the help guys
A 350 with 3.75 stroke, bored .060 over is a 388 not a 383. You also need 3.75 stroke pistons for whichever rod you decide to use, 5.7" or 6", they're different compression heights.
Semper Fi
  #17 (permalink)
Old 05-25-2012, 05:54 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
You don't need a new thread for every question regarding this 383 build. I'm merging the last two.
Semper Fi
  #18 (permalink)
Old 05-25-2012, 10:13 PM
never mine a question was already answerd
  #19 (permalink)
Old 05-26-2012, 11:17 PM
s10mannn's Avatar
merging the last two meaning ?
  #20 (permalink)
Old 05-26-2012, 11:56 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Meaning all your questions and the answers are now on this one thread- where you should keep your questions, instead of starting a new thread for each new question. See?
Some info that may help you is here, and here.
What are you putting the engine in? Is it set up for the power the engine will make, or if not are you budgeting enough for those changes that are inevitably needed when installing a high performance engine?
And why a 383 and not a 350 in the first place? If there is a good 350 crank already on hand, you can make a 350/355 SBC that will make good power and cost less than a stroker SBC.
What is my 383 worth now? stroker444 Engine 5 08-28-2010 04:11 PM
383 stroker worth it? 75GMCman Engine 19 10-11-2008 10:16 AM
What's a '65 Mopar 383 worth?? STATUTORY GRAPE Engine 7 05-07-2008 05:23 AM
is a 383 worth it? 76vette Engine 6 08-31-2006 10:18 PM
Roller Cam worth the extra bucks for SBC 383 making like 400hp?? 89SDime Engine 10 03-11-2006 02:22 PM
