350 - 383 worth it? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2012, 08:29 PM
s10mannn's Avatar
350 to 383, QUESTIONS
ok so im a little lost, i know a 383 is a 350 with the 400 rods and the 400 crankshaft, but what would it be if i bored it 0.30 over and instead of 8-1 compression i had 9.3-1? PLEASE HELP! All comments much appreciated
Old 05-24-2012, 08:53 PM
Greg T's Avatar
www.krusinklassics.net
3.75" stroke and .030" overbore is a 383.
Old 05-24-2012, 09:55 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
The formula for cubic inches is bore x bore x stroke x number of cylinders x .7854. This will give your answer.
Connecting rods and compression have no effect on cubic inches.
P.S. a 350 block cannot be bored .30 over, .030 over is what your looking for.
Old 05-25-2012, 05:45 AM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Thats how most 383s used to be made with the stock 400 crank and rods. Now a days its easier and cheaper just to use an aftermarket crank, 5.700" rods and pistons with the correct compression height.
Old 05-25-2012, 11:38 AM
s10mannn's Avatar
i just ordered the 383 with a .060" bore, whats the difference? i know the cylinders will be bored bigger but besides that
Old 05-25-2012, 11:47 AM
Blazin72's Avatar
Wiki Edits: 19
You'll have a slightly bigger engine. Do the math with the formula I gave you in my last post if you want to know what size it will be.
In order to help increase the useful life of the block only have ithe block bored the necessary amount to restore the cylinders then order the correct size pistons based on the the work the machine shop has done.
Old 05-25-2012, 11:57 AM
'49 Ford Coupe's Avatar
1949 Ford Coupe RESURRECTION
There is a LOT to building a 383
And whether you .030 over or .060 over is just the beginning. I learned a LOT building mine, and spend a LOT of money to get it right. But then... I got a BAD *** engine... hahaha
Wold be glad to give you a run-down, but I'm kinda in a hurry right now... holler back or PM me..
Old 05-25-2012, 11:58 AM
s10mannn's Avatar
ok so i think i got it straight, ill be using a 3.750 stroke crank with 5.700 length rods and 383 pistons with 9.5-1 compression and a .060" bore sound good ? ? ?
Im obviously still pretty new to this but i appreciate the help guys
Old 05-25-2012, 12:06 PM
compression ratios
good target plan. Here's the deal, though.. your compression ratio is entirely dependent on the heads and gasket thickness, then calculate which pistons to use. there are lots of "calculators" on the web to come up with your "cc allowance" for the pistons. If I had it to do over again, I'd buy the Summit or Jegs FULL 383 stroker kit, including the crank, pistons, rods, rings, etc.
get your head before you do anything else and decide what you will be doing with them before settling on pistons.
Holler back if you'd like a link to my build, or click on my member thingy with a link to my build.
Old 05-25-2012, 12:23 PM
Blazin72's Avatar
Wiki Edits: 19
Has the machine shop already machine or looked at the block? How do you know you need .060 over pistons? Are your pistons designed to be used with 5.7" rods?
I think you need to pick up some books and start reading about basic engine rebuilding.
Old 05-25-2012, 02:45 PM
s10mannn's Avatar
i know .060 over is a big bore but thats what ill be able to get my hands on but no i hasnt been bored so ill need to have them bore it see what im at then go from there and yes the pistons are made for the rods
Old 05-25-2012, 02:54 PM
s10mannn's Avatar
350 - 383 worth it?
I have a 1988 350 sbc and i was wondering if its worth it ($$$$) to make it a 383? i believe it will run me about 550-600$ for everything.(friend doing the labor) motor will be completely rebuilt and have some performance parts such as rpm intake manifold full exhaust headers back magnum cam 270H maybe bigger ect...
Old 05-25-2012, 03:37 PM
cool rockin daddy's Avatar
So you're asking if 33 cubes are worth $600 to you? Only you can answer that.
Even if the machine work is free , you had better set aside 1500-2000 to build a decent stroker !!
dave
Old 05-25-2012, 03:39 PM
How many threads are you going to start about this engine?
What is my 383 worth now? stroker444 Engine 5 08-28-2010 04:11 PM
383 stroker worth it? 75GMCman Engine 19 10-11-2008 10:16 AM
What's a '65 Mopar 383 worth?? STATUTORY GRAPE Engine 7 05-07-2008 05:23 AM
is a 383 worth it? 76vette Engine 6 08-31-2006 10:18 PM
Roller Cam worth the extra bucks for SBC 383 making like 400hp?? 89SDime Engine 10 03-11-2006 02:22 PM
