Hotrodders.com Streetbeasts lawsuit Beat the Beast -- defend free speech!
Streetbeasts lawsuit fundraiser
Goal: $10,000. Amount raised: $3,440.
Get the latest news on the lawsuit.
Thanks donors!
Click here to donate, or see more details about donating.
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 05-11-2005, 11:26 AM
fearsomefairmont's Avatar
fearsomefairmont fearsomefairmont is offline
350 4-bolt main - Block Strength?
Hi Folks,
I was wondering if any of you folks have a rough estimate of the horsepower a properly prepped 350 4-bolt main block can take. I searched but didn't really find an informative answer.
Imagine the bottom end has ARP studs, and it is used in a boosted application with a .030 overbore (no 7500+ rpm).
I am familiar only with Ford blocks, the 351C blocks generally good for a reliable 550-600 hp with 2 bolt studded mains, the early 351W blocks up to 800 hp with 4-bolt conversion.
I am curious to hear, particularly from Turbo s-10. I have acquired this very mint 350 very cheaply, as well as an '81 Malibu Wagon and a '65 toploader 4-spd I have lying around. I was thinking of turbocharging the motor with a DIY fabricated kit and two Garrett hybrid turboes, hence my concern for block strength.
I would like to make lots of power but by the same token not build a time bomb, or at least one that ticks too rapidly :~) $2500 aftermarket blocks kills the budget pretty quick.
Cheers,
Andy
Old 05-11-2005, 11:34 AM
GoneNova/406's Avatar
GoneNova/406 GoneNova/406 is offline
if you stop and think that back in the day when 327's ruled and they were all 2 bolt,racers used to routinely run 750 h.p. and now you have nextell cup cars running 750 but those blocks are slightly beefier.you can also get cap straps for 2 bolts or even turn a 2 bolt into a 4 bolt which is stronger than a factory 4 bolt anyway.ask anyone who runs a 2 bolt 400 block.
Old 05-11-2005, 12:06 PM
edge's Avatar
edge edge is offline
Time is short, are you ready?
http://www.hotrodders.com/t57867.html
Opinions will vary, but I found one source that stated: "4-bolt blocks with ARP main studs are good to 700 HP, and are good to 8500 RPM"
Ed www.edgesz28.com
Old 05-11-2005, 01:19 PM
Sorry for the redundant question
Hey Guys,
Thanks for the link to the previous thread. Didn't realize it had been addressed before, maybe I need to get better acquainted with the "search" function.
Anyways, I think the 4-bolt will fulfill my needs fine. If I come upon a good deal for a Bowtie I might pick it up.
Thanks for all your input -
Andy
Old 05-11-2005, 01:59 PM
airman_turtle's Avatar
airman_turtle airman_turtle is offline
y two turbos? the whole twin turbo concept is so overrated. Just get one bigger turbo and its more than you will ever need. The only use of TT is for looks.
Old 05-11-2005, 02:39 PM
oldschoolrods's Avatar
oldschoolrods oldschoolrods is offline
Not nesecarly true. If you go too big you will get turbo lag. By running multiple turbos you are able to series them to eventually power a big turbo.
Old 05-11-2005, 03:28 PM
Siggy_Freud's Avatar
Siggy_Freud Siggy_Freud is offline
Siggy_Freud's barnstar
Wiki editor
Where are you getting your info at ? Do you have any evidence to back up this statement? I am sure the fellers over at Lingenfelter would be quick to disagree with your statement.
1997 BMW M3 - 3.2litre Inline 6 cylinder
Old 05-11-2005, 03:41 PM
The reason they do it is because it is easier to fit two small turbos than one big one on a corvette. But overall it is an unefficient design...the reason a lot of people with twin turbo cars convert to a single turbo design.
and here...
that nova runs low 7s...one turbo
Dan Millen...one turbo...and up until a few months ago the world record holder on 10.5 tires...7.1@198
But they are as big as basketballs lol
Old 05-11-2005, 05:20 PM
Exactly
Packaging is the big issue for two turbos. It is easy to stash them in the front, away from the accessory drives, and save the fenderwells.
A single turbo is the way to go, efficiency-wise, although those single turbo setups for drag cars are not real streetable. Many don't start to spool because their huge size (due to the size of the inducer) until 3500+ rpm, and then boost comes on like a freight train. Plus, there is no way to fit a basketball size turbo in a car with fenderwells and stock front accessory drive.
Anyways, I am familiar with the implications of each setup. I was more concerned with blowing up the foundation of the whole effort, the block, though. I need to start shopping for a good fuel injection computer, I was thinking the Electromotive Tec(3) with DIS, seems to be a reasonable $1700 or so.
Cheers,
Andy
Old 05-11-2005, 06:39 PM
spinn spinn is offline
Hooligan on a Holiday
oh my god. thats awesome!
Old 05-11-2005, 07:29 PM
56Maynard 56Maynard is offline
The maximium hp levels that the OEM block will contain will vary with the type of use its destined for. High rpm launches have been breaking those blocks since the 60s without turbos.
In fact, you can occaisionally pull those blocks out of the original car and find cracks in the main webbing at the factory hp ratings.
The term "reliable" is important in that what I consider reliable and what you consider reliable may differ. For me to convey reliability to you, you'd need a "benchmark" of what I consider a reliable street motor.
To me, a reliable street performance engine would have to go 100,000 miles to meet my definition of reliable. I think this is where all of the differing opinions come into play. Some folks obviously consider shorter service lifes of engines as being reliable.
That being said, I think you could make that 4 bolt block live 100,000 miles at 500 hp if you did not use the engine for drag racing and carefully maintained it. You'd really have to pay very close attention to the tune up so as not to get into detonation under boost and beat the webbings, crank, bearings, rods and pistons right out of it. You can easily get to this power/reliability level without a turbo.
If on the other hand, you wanted to go to 800+ hp reliably, you'll need to spend some money on a block to know for sure that you wont have cast iron pieces on the pavement.
Its no secret that guys are getting 1100-1200+ hp out of blown injected small blocks on alcohol but they are far from 100,000 mile motors and the owners are never surprised by block failures.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "350 4-bolt main - Block Strength?"
Bearing Spacers- 283 crank into 350 block jhs914 Engine 13 07-18-2009 09:06 AM
350 block 69 chevelle SS Engine 7 09-02-2005 02:21 AM
350 short block and long blocks? Brian Morency Engine 5 09-16-2004 02:07 AM
350 Block novatech Engine 2 11-25-2003 08:07 PM
4 Bolt Block HotRodS10 Engine 16 05-21-2002 06:27 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2010. All Rights Reserved.
