350 with 400 rods? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-05-2002, 01:58 PM
slider in wa's Avatar
Slider in Wa.
Post 350 with 400 rods?
Did i understand that it can be done? Did i understand this would product 11:1 compression and will run on 87 octane? What crank would i use? the 400 or the 350? If i use a 400 crank then it becomes an internally balanced engine right?
Thanks
Slider in Wa.
Old 11-05-2002, 03:17 PM
Post
I too have heard that shorter rods enable a slight compression increase for the same grade of gas, this is why chev used such a short rod in the 400. but i had a 377 one time with 400' rods and the sort rods made it a b!&$ to keep the bores clean. by the time i got done romping on the motor fora year(yes teir was a correctbreak in period}the walls were shaped like a piramid.
soon after that i read some books by david vizard and smokey yunik and they preached heavily against the shorter rod. but i have to say-it made some reall good downlow power--hope i helped
Old 11-05-2002, 03:20 PM
Post
ohh yeah -i left something out--the 400 crank is externally balanced,but you can have it internally balanced with heavy metal in the counterweights for a hefty sum of money
Old 11-05-2002, 04:39 PM
F-1Rodder's Avatar
Post
I find it hard to believe that 11:1 will run on anthing but super gas.
Old 11-05-2002, 04:54 PM
BOBCRMAN@aol.com's Avatar
Post
you cannot put a 400 crank in a 350 without having the mains turned to 350 specs, around this area you can buy a 383 cast stroker crank for very little more money and have a better crank, you have to have the thing balanced anyway so why not do it right and use a 5.7 or longer rod and correct piston. short rods are hard on cylinder walls, gm built the 400 with a short rod for production economy, they did not produce this motor for high performance, most had two bbl carbs. they just wanted a torque motor for all the big barges they were producing.
Old 11-05-2002, 07:35 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
I think you missunderstood. There is no practical reason for putting shorter 5.65 400 rods in a 350, and I would be surprised if there were pistons out there to support this. You can put aftermarket 6 inch rods in the 350. I think the statment about 11:1 on 87 is a misinformed one. If a tight lsa cam was used you might be able to run 93 on 11:1, and that is a big might. I would stick to 10:1 and save yourself the grief of 11:1. The performance advantage is not work the chance that it will be a huge pain in the *****
Chris
Old 11-06-2002, 05:27 AM
Slider in Wa.
Post
Thanks Chris and guys. I was just trying to reason out the 11:1 comp on 87 octane. I am not building this, just trying to understand a previous post i read on here. So thank you all.
Slider in Wa.
