Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350 to 454 in 77 C10
Old 07-06-2010, 05:26 AM
poncho62's Avatar
poncho62 poncho62 is offline
Wiki Edits: 5
A big block Chevy has the same mounts as the small block....should bolt right in.....the bellhousing is the same pattern too......As long as you have an oil pan for a truck frame, there will be no clearance problems. The car ones may clear too..........You will need big block headers for a truck frame
