Thread Tools Search this Thread share on Facebook
  #1
Old 12-12-2011, 06:36 AM
bigtread's Avatar
bigtread bigtread is offline
from 350 to 454
Hey guys,
I am pulling my 350 out of my mud truck and installing a 454, don't know anything about the 454 other than it runs real good.
I currently have a 4500 stall torque converter in 400 turbo that worked great with my 350, question is should I look at replacing the torque converter with a different stall speed to run 454. I was told that it my need to be lower stall speed.
Thanks for any info
Register now (free) or login to remove ads
Old 12-12-2011, 06:50 AM
cobalt327's Avatar
WFO
Wiki Edits: 1,616
Originally Posted by bigtread
Hey guys,
Thanks for any info
You want the TC to hit at the torque peak, so it will depend on where that is w/the 454. I wouldn't be a bit surprised if you needed a tighter TC, though. If the current TC is stalling at 4500 w/a SBC engine, there's a good chance the torque of the BBC will cause the stall speed to be higher.
But in any event what you don't want is for the stall RPM to bypass the meat of your 454's torque curve and if the stall speed is too high, it will do just that.
Old 12-12-2011, 07:25 AM
bigtread's Avatar
When you say tighter torque converter does that mean a lower stall speed?
Old 12-12-2011, 09:21 AM
68NovaSS's Avatar
68NovaSS 68NovaSS is online now
Last journal entry: Fresh paint
Wiki Edits: 9
Moving to the trans forum.
''Life's tough, Pilgrim, and it's even tougher if you're stupid.''---John Wayne
Midnight Sun Street Rod Association
Back to top
Search this Thread:
Advanced Search
vB code is On
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
