Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 02-01-2004, 10:06 AM
punk1c5040 punk1c5040 is offline
350 4x4 trans to 700R4 2x4 trans swap???
i have a 350 trans with what i beleave is a 205 tranfer case i want to drop the 350 trans and put in a 700R4 2 wheel drive trans would i be able to take the output shaft from the TH-350 and use it in the the 700R4?? if so how hard is to to remove the output shafts from the them?
Old 02-01-2004, 11:14 AM
poncho62's Avatar
poncho62 poncho62 is offline
Moderator
 poncho62's barnstar
Wiki Edits: 5
re: 350 4x4 trans to 700R4 2x4 trans swap???
Don't know if they are interchangable.......however, I do know, that you have to pull all the guts out of the trans to change the rear shaft. Easier to find a later model 4X4 trans with overdrive.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
