350 6.125" rods - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-15-2006, 12:10 PM
350 6.125" rods
Are there any clearance issues when using a 6.125" rod in a 350? I will be using a 3.48" stroke stock crank. Will the rods possibly hit the bottom of the cylinders?
Old 09-15-2006, 12:25 PM
nitro_baller4692's Avatar
floppers forever
not only that be make sure it don't hit the cam or the oil pan rail all can be notched except the cam.
Old 09-15-2006, 01:03 PM
engineczar's Avatar
If you're using the stock stroke I would say that you'll be fine.
Old 09-15-2006, 01:09 PM
I don't know why you'd want to do it as it puts your pin height way up there. I see no benefit, only drawbacks.
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 11:00 PM
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 04:00 PM
Why not a 350 sbc? bowtieorbust Engine 29 09-05-2008 10:43 AM
Where is the best place to find a 350 engine Andrew7dg Engine 8 10-20-2005 05:28 PM
305 vs. 350 question DesertPanel General Rodding Tech 4 10-16-2003 09:19 PM
