350 89 corvette help - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-27-2008, 08:36 PM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
Sweet.
Don't forget to put a short (3/8"-16x1/2") bolt where the arrow is. Use some sealer. It Intersects the fuel pump push rod and can create an oil leak if not blocked.
  #17 (permalink)
Old 09-27-2008, 08:43 PM
daoriginator64's Avatar
its funny there was never a bolt there to begin with?? and i never had oil leaks or anything????????
  #18 (permalink)
Old 09-27-2008, 08:47 PM
C-10's Avatar
Revolution Calling
Maybe the later model blocks weren't drilled all the way through. The earlier ones will leak there. Well at least mine did.
  #19 (permalink)
Old 10-06-2008, 04:42 PM
done! completely works i ran the car yesterday, few things! i had to delete the fuel regulator i had there for the electric pump. and i also had to adjust the electric choke for some reason i had to advance it because it was super reved, also the fuel mechanical pump i bought on ebay was no good, it just kept leaking form the fittings and i tried numerous times until i got fed up and drove to autozone and bought a 20 dollar mechanical pump! but all is good now! woohoo!
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
DEBATE: Which heads are better?....Chevy 350, Pontiac 350, Olds 350 or Plymouth 350. Steve-0321 Hotrodding Basics 21 11-26-2007 12:44 AM
305 head on 350 savman1 Engine 4 10-15-2006 09:18 PM
305 vs. 350 question DesertPanel General Rodding Tech 4 10-16-2003 08:19 PM
