350 Backfiring out of the carb - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-24-2011, 01:50 PM
1970 CST/10's Avatar
I have a 70 chevy with a stock 350 i recently put a HEI distributor, new plugs, and plug wires (three months ago) and a Edelbrock 600 carb with electric choke(last week). It has recently started backfiring out of the carb. Any ideas what could be causing this.
Old 01-24-2011, 02:11 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
When exactly does it backfire through the carb ? If it was running good until now. Check and see if the distributer is loose.
Or it could be a cam going bad on you.JMO
And re-check the carb adjustment and check for vacuum leaks around the carb. JMO
Cole
Old 01-24-2011, 02:41 PM
DoubleVision's Avatar
Check the voltage going to the HEI. It must get 12 volts. It will run on as low as 8, but it`ll kick, buck and backfire.
Old 01-24-2011, 04:09 PM
it backfires about 45-55 mph (it dosent have a tach) it ran fine for a while after I put the distributor on but went down hill about a month ago
Old 01-24-2011, 04:45 PM
bondo's Avatar
Ayuh,... You just changed the Carb,..??
I'd guess the settings, or jetting is Off, 'n it's a Lean backfire...
Old 01-24-2011, 04:50 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Any audible symptoms, rocker noise? Hard starting?
Old 01-24-2011, 05:15 PM
it may be the carb but i wouldnt think so since it was doing it before i put it on, the carb did help for about a week but its back at it again,and it sounds great at idle
Old 01-25-2011, 01:31 PM
vetteman2's Avatar
re-time the engine.
If it does it after you re-time it, Pull the cam out.
Old 01-25-2011, 02:23 PM
bondo's Avatar
Ayuh,... Fuel Filter,..??
Old 01-25-2011, 06:32 PM
bubbahotep's Avatar
Im voting in as a timing issue perhaps. Have you checked the entire timing curve since the backfire?
Old 01-26-2011, 07:30 AM
Make sure the firing order is correct...and the distributer cap is completely on...(has a little tab that fits in a slot)...check for vacuum leaks...I put a rag over the carb and spray ether around the carb and listen for a change in the engine noise...not the safest way...but im a redneck and it works..lol..make sure a rocker arm didnt pop off...check the timing...if all else fails its a cam lobe failure.
Old 01-26-2011, 06:57 PM
My 383 started doing that on a TBI setup and what happened was the poly lock backed off on #7 exhaust and there was no where for the exhaust to go and that was the culprit. Not sure that is your issue but something to keep in mind.
Old 01-26-2011, 08:02 PM
GMCTRUCKS's Avatar
Check to see if all the parts in the dizzy are moving as they should.
350 backfiring through carb CuttyGMachine Engine 6 06-09-2008 07:28 PM
Carb backfiring cares Engine 6 05-03-2008 01:52 PM
carb backfiring grapro Engine 9 05-26-2007 03:06 PM
backfiring through carb crashtestcowboy Engine 2 05-23-2006 10:54 AM
carb backfiring nativechoppers Engine 3 02-06-2004 05:23 AM
