350 backfiring through carb
- 350, .030 over, MSD ignition, distributor (w/vac secondary) and coil. RPM Air Gap manifold and 1411 carb. True dual exhaust with cats.
- 12deg initial timing. Hasn't run long enough to set total timing. - Hard to start, takes a lot of cranking and feathering the throttle. - Noticed fire in the headers before I buttoned up the exhaust when it was running for a few seocnds at a time. - Now backfires through the carbs and even burns for several seconds in secondaries after killing engine. I need some help guys. Any ideas? thanks stu... |
Is this a fresh rebuild
Are you sure that the distributor is in correctly, how are you checking initial timng if it wont run. I would look at the timing, firing order and valve adjustment in that order. Any of the three will give the symptoms you have described Chet |
It is a new cam install. I got it to run yesterday for several minutes, albeit at a higher idle than normal. I guess that could have screwed up my timing work. I have checked the distributor and wire order. I will double check valve adjustment, but I'm pretty sure that is OK. Is there an easier way to do the valves than bumping it with the starter? Now that I have the engine buttoned up I can't just turn the crank by hand to get to the next valve.
thanks |
You guys hit it right on. I did another valve adjust and the engine started right up. Not sure how they got that out of whack, but I found some too tight and some too loose. Anyways, it roars now!
thanks stu... |
| carb backfiring | grapro | Engine | 9 | 05-26-2007 03:06 PM |
| buick 350 carb | wranglr88 | Engine | 2 | 05-10-2007 12:08 AM |
| carb 350 engine into a 98 V6 camaro | boola | Engine | 1 | 12-29-2006 05:10 PM |
| what carb has best mpg and performance on 350 chevy? | 72chevyelcamino | Engine | 5 | 10-22-2002 09:48 AM |
| 350 carb help | Lightspeed | Engine | 7 | 10-10-2002 10:45 AM |
