350 bad low idle
I have a 1994 chevy silverado with a throttle body carb.
The idle runs very low , and then sometimes fast when setting in park. Drive it down the road and it runs perfect. Anyone got some Ideas? Thanks JTN |
350 bad low idle
Have you checked for vacuum leaks? Use carburetor cleaner and spray along the intake where it bolts to the heads. Also spray along front and rear gasket and the throttle body base. If the idles speeds up that is where the vacuum leak is. Is your check engine light on? You need to get a full scan on the OBD1 system. get a REAL reading on the OBD1 system so you can see what all the sensor values are at when the truck is at full operating temp and at startup. Scanner will tell you what your IAC counts are, pulses of the injectors, voltage at the TPS through the whole throttle range, millivolts on the O2 sensor, timing adv/ret, knock counts ( retards the timing when they happen) even the hydraulic pressures in you tranny.
thanks cdminter59 I thought a vacuum leak myself, and you are
correct, a full scan is in order. Thanks a bunch jtn |
cdminter59 my check engine lite is not on
thanks jtn |
| 350 VERY rough idle after bad oil gauge | topdogger | Engine | 21 | 09-25-2006 07:16 PM |
| Low idle vaccum in gear on SBC 350 | hotrodf1 | Engine | 14 | 04-12-2006 07:21 AM |
| Help 350 rocket bad timing chain & low oil pressure? | 71oldsmann | Engine | 2 | 03-14-2005 11:45 PM |
| 350 sudden rough low idle | JohnnyGTO | Engine | 9 | 06-19-2004 06:52 PM |
| Low oil pressure at idle on rebuilt 350 | Palmtrees57 | Engine | 25 | 02-13-2004 10:30 AM |
