350 bent dipstick - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-06-2010, 10:44 PM
350 bent dipstick
Got 85 chevy 350 new engine bored 40 over new everything. 4000 miles,this engine started having a pinging sound. sounded like a valve ping. after trying all the obvious found the dipstick bent and a inch missing from it. What happened here any ideas on what hit it?
Old 08-06-2010, 11:05 PM
ericnova72's Avatar
More for Less Racer
Is the lower dipstick tube in place?? The one in the block down past the main cap.
It guides the stick past the main cap and keeps the crank from hitting it, guiding the stick down into the pan instead of letting it curl.
Old 08-07-2010, 02:36 PM
thanks
I thought I bent rod or worser. that might be fixable without pulling the or motor. Going to check it out need to get oil pan cleaned out any way. Thanks for advise.
Old 08-07-2010, 04:08 PM
bigdog7373's Avatar
Of course it's fast
An inch missing off the dipstick could be because whoever built the engine bought too long of a dipstick and just cut it so it would fit instead of buying a shorter stick. But the doesn't explain the pinging noise. Just a thought.
Old 08-07-2010, 06:04 PM
It was the right one. It ground the end off. It would only make the raked every once and while. until one afternoon when i got home hit the fuel a few times, then noise got loud and didn't stop. shut it off and started back up noise stopped. got out to inspect damage, tried to pull dipstick out it was stuck. finally got it out it. the part that was left is bent in 90 degree angle.
Bent Push-Rod on Chevy SB 350! 32Hoopie Engine 12 08-08-2010 08:46 AM
Nova ('69) / turbo 350 / dipstick tube Nova901 Transmission - Rearend 5 12-08-2009 02:18 PM
350 oil dipstick side change dagoat_1 Engine 5 11-30-2009 01:15 PM
350 dipstick on other side? cutthroatkid Engine 4 10-29-2009 05:34 PM
Oh crap!! 350 or 327?? Biscuit6447 Engine 21 08-28-2009 11:59 AM
