350 block with 305 vortex heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2011, 11:02 PM
i have a stander bore 350 motor with keith black 100 dome pistons and 305 vortec heads and vortec intake . what left of cam do i need to run in it i am going to run a 650 edelbrock carb
Old 02-08-2011, 11:10 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
What left of cam? Not sure what that means?
Old 02-08-2011, 11:27 PM
DoubleVision's Avatar
I think he`s asking what cam he should run. But first, What is the intended useage of this engine? Street? race? off road? Need more info.
Old 02-08-2011, 11:36 PM
street car
Old 02-08-2011, 11:37 PM
street car 72 venture
Old 02-08-2011, 11:41 PM
Your combo has issues. 305 heads aren`t the hot tip. They don`t flow no where near L31 Vortec heads do. Second, dome pistons and the small 57cc chambers on the 305 heads will put your compression ratio over 11:1.
It wouldn`t run on pump gas without detonating itself to death in very short order. You`d have to use 110 octane leaded gas that costs around 12 bucks a gallon.
400 cid with vortex heads gaino Engine 1 08-13-2010 06:47 PM
350 vortex heads KzyCkr Engine 1 03-13-2010 08:24 PM
What Is A Vortex Engine ? mercury man Engine 15 11-23-2008 03:35 PM
vortex heads toeme Engine 2 10-11-2005 11:34 AM
vortex heads gaino Engine 15 03-02-2003 08:01 PM
