350 Block - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2006, 09:52 PM
350 Block
I have a 1995 350 block. the parts to rebuild the block are from a 77 350 block. con i use some of the pars? also can i put the 77 350 heads on the 95 350 block.
Old 03-06-2006, 11:00 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
What vehicle is the donor for the 95 engine? In 95 there was a traditional small block which would share many things in common with the 77. There is also the LT1 350 which shares a few things with the 77.
Old 03-10-2006, 12:10 AM
The '77 crankshaft won't work because of the different rear main seal design. An adapter can make it work, but it would probably be cheaper to get a good used late-model 350 crank. The heads should bolt up fine.
Old 03-10-2006, 02:30 AM
curtis73's Avatar
Wiki Edits: 16
... if the 95 isn't an LT1
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
Hi. just wondering why the 350 chevy small block is so good... judgedredd Hotrodders' Lounge 78 06-25-2010 08:01 AM
350 main 3.75 stroke crank in 400 block onebad98z Engine 5 04-28-2005 09:17 PM
350 chevy small block ?s 350MC Hotrodding Basics 19 06-16-2004 10:08 AM
