350 In BMW - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-19-2010, 09:02 AM
Tony313's Avatar
350 In BMW
Hey everyone. I recently convinced my dad to hand the keys over to me of his 1987 BMW 325i convertible which we have had in our family a while. The head gasket and piston compression rings as well as first gear is shot on the tranny. I want to do something unique to it (not like every tuner on every corner). I was thinking about dropping a 350 chevy small block in it. I love the concept. Let me know what you think and I am open to any and all ideas!!!
ID:	48168   Click image for larger version
ID:	48169   Click image for larger version
ID:	48170   Click image for larger version
ID:	48171   Click image for larger version
Old 09-19-2010, 03:44 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
First welcome to the site, And second if it's really what you want to do,
Go for it and have fun in the process.
Cole
Old 09-20-2010, 12:16 AM
Landshark928's Avatar
FrankenPorsche
Thought about a ford?
http://e36v8.com/
Here's a Chevy kit.
http://www.nash8503.com/Conversion_Kits.html
Should be fun. You can search the internet to find DIY solutions that will save you big $$ over the kits. However the kits are tested and come complete.
Old 09-20-2010, 02:23 PM
eloc431962's Avatar
Wiki Edits: 37
Yep a 5.0 with a 5-Speed would be pretty sweet in it.
Cole
Old 09-20-2010, 02:34 PM
BMW/Chevy
Tony,
Go for it! A LS2 GM motor in that Bmer would rock!
Good luck!!!!!
Old 09-20-2010, 03:24 PM
SS66chevelle's Avatar
HR VIOLATION
Lesson learned the hard way several times - if its available in a kit buy the kit! I've spent so much time on DIY this or that and it seems like I spend twice as much time and nearly as much money (or more sometimes) trying to get it right..
http://e36v8.com/
Here's a Chevy kit.
Old 09-20-2010, 04:16 PM
I agree that buying the kit is probably cheaper in the long run, but DIY is more rewarding to me. Heck, buying a completed, running car is cheaper than building one.
Old 09-20-2010, 05:43 PM
FrankenPorsche
I agree about the journey being more satisfying than the end. However after you have pulled the engine for the fourth time to replace a pilot bearing because you were off on your measurements ever so slightly, you'll appreciate the kit. You still get to put everything in. It's far from easy and still requires a lot of McGuivering at times.
My kit bolted the Porsche torque tube and tranny to the SBC. I was on my own for everything else. Electrical, headers, power steering, oil coolers etc.. I let someone else's dime figure out the expensive stuff.
If you have mad skills and the equipment then go for it. You'll have pride no kit owner can have. It took me 10 months for a 3 week install with a kit, no way I'd have time to do it myself from scratch.
Old 09-20-2010, 08:58 PM
Last journal entry: Unpacking
i think it would be BA, you'd have a sharp car with the affordability of a chevy
Old 09-21-2010, 09:43 AM
HR VIOLATION
Ahh to be young again! this is, I am afraid a lesson that you will have to experience for yourself to appreciate the "wisdom" of the advice in using a kit.. same thing happened to me and just about everyone else I know... As much as we all want to be chip foose (or enter your fav rodder here) the reality is that we do this hobby in a small garage with a handful of tools, some of which weren't designed for the job (like removing a body from a frame with a cherry picker and saw horses).
do yourself a service and buy the kit, unless you plan to use the car as a conversation piece that sits in the garage for years without moving while you rework it a dozen times to get it right. You can still take lots of pride in doing the job yourself - a very amazing feat in itself in this era where no one even opens the hood to check their oil anymore.
Old 09-21-2010, 10:33 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I would do the complete swap and use the GM trans as well..that will save a lot of heartburn..
Sam
Old 09-22-2010, 08:34 AM
Tony313's Avatar
Thanks guys for the feed back. I am also a culinary student so funds are tough. Im doing the body on it now as its alot cheaper then the 350. But unfortunately its not running.
Old 09-22-2010, 08:54 AM
Wiki Edits: 3
I have no clue as to the driveshaft situation on a BMW..hopefully it is an open driveshaft on that car..if it is then if you use the complete engine trans combo from a donor car making a driveshaft that is Gm on one| end and BMW on the other is not hard..Get on cragslist and source a donor car there in the local area and just use the stock motor and trans for now to get everything together and running and then worry about hotrod parts after that..much easier that way and cheaper and doable as well..
Sam
Old 09-22-2010, 09:07 AM
i have a 58 mercedes that has a 350 sbc...ended up using the whole frame from a 79 malibu wagon...had to shorten it to get the wheelbase correct and build trunk to alow spring mounts to clear and of course build body mounts....but very happy when i need parts that they are cheap and common
Old 09-22-2010, 10:05 AM
It is, and you are completely correct. Use a matching engine/trans combo and make a custom driveshaft. This is MUCH, MUCH easier than the alternative. I have an 86 E30 that's in line to get a Northstar/700-4R swap (the SBC thing is SOOOO overdone... ).
The biggest problem with a V8 swap into and E30 is the power brake booster. Consider a hydroboost.
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 01:38 AM
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 04:00 PM
Cam/Lifter Question about Ramjet 350 Jake Harsha Engine 20 07-07-2010 07:22 AM
305 head on 350 savman1 Engine 4 10-15-2006 10:18 PM
348 or 350 delimma 62ImpalaSS Engine 12 05-18-2006 12:03 AM
