350 bolt on 3sp - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-15-2002, 01:45 PM
New Member
Question 350 bolt on 3sp
Will a 350 bolt up to an original 3 speed in a 51 Chevy pickup? If not is there another 3 speed that will work.
Thanks
Bd
Old 05-23-2002, 08:03 AM
CARGUY's Avatar
Post
it should i had a inline 6 in a 63 impala i swapped a 327 into i used the same 3 speed ,flywheel,clutch,belhousing and starter
Old 05-23-2002, 05:11 PM
Post
the older trucks had 2 different sized bell housings.as long as the bolt pattern on yours matches the 350,there should be no problem
