Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350 bored .060 over... XE268 cam, I didn't put a CAM BUTTON IN!!!
Old 05-14-2005, 05:25 PM
NAIRB's Avatar
NAIRB NAIRB is offline Moderator
The reason why you don't need one is because the lobes on a flat tappet cam are tapered. The lifters have a slight conical shape on them, and this causes the lifter to rotate, it also creates a rearward thrust on the cam when it is running.
You can put a cam button on any hydraulic or solid lifter cam if you wish, but it's not necessary to do so. A roller cam, however is a different story because the lobes are not tapered, and of course, a roller cam will not tolerate any walking back and forth as roller lifters don't do well skidding accross the lobe sideways.
