350 build - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-23-2012, 07:59 PM
350 build
1972 350 going in a 79 dump truck. looking to rebuild as cheap as possible and get as much low end power. Any sugg would be appreciated. Its a weekend warrior/wood truck.
Old 02-24-2012, 11:35 AM
dinger's Avatar
Here is a decent post on this. 350 Chevy Torque Motor
You may want to use the search function, try 350 Chevy torque motor as a search. This has been done many many times, I think some of our engine guys get weary of answering the same questions. Good luck.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 02-24-2012, 11:40 AM
lt1silverhawk's Avatar
"But how do it know?"
Last wiki edit: How to rebuild a Rochester Quadrajet 4MV carbureto... Last photo:
Wiki Edits: 132
In addition to what Dinger has recommended:
If you are new to engine building, check out this wiki: "Chevrolet engine rebuild guide books and DVDs". These titles are regularly recommended by the members of this forum.
If you are shopping around for specific recipes, know Mr. Techninspector1 usually recommends this page: "Small Block Chevy Dynoed Combos". Tons to pick from.
You may also wana check out the latest Car Craft issue. They do a budget build using a crate motor.
468 build for 500 hp hotboy454 Engine 2 08-14-2011 02:38 PM
355 build??'s about compression and build impalaman355 Engine 5 06-06-2011 11:20 AM
327 build. what else would you do? 65smallblock Engine 36 01-21-2009 06:26 PM
USA BUILD vs CANADIAN BUILD? troy norrad Hotrodding Basics 19 02-18-2008 10:57 PM
200-4r experts - build questions - Which core is best to build on? Warrant Transmission - Rearend 7 10-09-2007 08:36 PM
