350 Build Cast #3970010 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-26-2013, 08:40 AM
NovaLou's Avatar
Block is ready except for decking and I just received my Promaxx Freedom Series Aluminum heads 64cc from summit along with my 0.030 pistons. Still trying to find out exactly which Howard Roller Cam kit to buy for this block. Looking to get 350-400 HP on a budget. Filled out the Cam form on the sight but haven't heard back from the Howard Cam expert. Any suggestions while I wait? I still have lots more parts to buy for this budget build.
Old 05-26-2013, 08:45 AM
vinniekq2's Avatar
have you done a test assembly for piston to bore clearance?
Old 05-26-2013, 08:50 AM
NovaLou's Avatar
No sir, just got the pistons yesterday from Summit, no rods though.
Old 05-26-2013, 08:55 AM
Proud LOSER
Think we did this already?
You did order the heads with an upgraded valve spring for a roller cam correct?
But here goes
http://www.summitracing.com/parts/hr...make/chevrolet
http://www.summitracing.com/parts/edl-7101
http://www.summitracing.com/parts/su...50vs/overview/
http://www.summitracing.com/parts/hup-gm30/overview/
Old 05-26-2013, 08:57 AM
Proud LOSER
Stock crank and rods will meet your goals and help your budget
Old 05-26-2013, 08:58 AM
vinniekq2's Avatar
do you know your static compression ratio yet?I think 400 hp is where you will end up if you take care with assemble and have the bolt on parts to match.
I would like you to have about 9.5:1 for a street engine.
did the heads come with springs,hope not,,,just valves and use springs from cam manufacturer
The Following User Says Thank You to vinniekq2 For This Useful Post:
NovaLou (05-26-2013)
Old 05-26-2013, 09:08 AM
NovaLou's Avatar
Got the heads but still need the double springs, I filled the form out on the Howards site to try and find the correct cam. But looks like you found it: the retrofit hydrolic roller cam thank you.
Old 05-26-2013, 09:10 AM
NovaLou's Avatar
Heads came assembled with springs so I have to swap for double springs.
Old 05-26-2013, 09:17 AM
Proud LOSER
For that make sure you get Howard's reccomondation.
The Following User Says Thank You to bygddy For This Useful Post:
Old 05-26-2013, 09:21 AM
vinniekq2's Avatar
I agree with dave about performer RPM and 750 carb
do you have decent headers? I think you are well on your way to a great and powerful street engine.
whats the home of the engine? do you have pictures of the car/truck
Old 05-26-2013, 09:28 AM
NovaLou's Avatar
Don't know my static compression yet. Should I contact Howards cams for the correct double spring?
Old 05-26-2013, 09:30 AM
NovaLou's Avatar
No I don't have the headers yet, I was thinking to get the cam kit next. trying to buy something every two weeks.
Old 05-26-2013, 09:37 AM
NovaLou's Avatar
I'll see if I can figure out how to post pictures. my Avatar is a picture of the heads.
ID:	74313   Click image for larger version
Old 05-26-2013, 09:43 AM
NovaLou's Avatar
Not sure what the block come out of I bought it in Squaw Valley, Ca
cast# 3970010
Proud LOSER
Love 70ish Nova's.....and the flat grey and ralley wheels just screams street bruiser....
3000 stall, 373's, sticky 275 drag radial and the motor as planned should make for a really fun mid to high 12 sec street car.
Wanna trade for a pretty third Gen Trans am lol....
Chevy 350 Casting 3970010 misswriter415 Hotrodding Basics 13 08-23-2012 01:07 PM
Is My Chevy A 350 W/this Casting Number 3970010 CHEVY70 Hotrodding Basics 7 05-16-2010 08:06 AM
327 Cast#3970010 70GMC_L/B_S/S Introduce Yourself 2 08-16-2007 02:53 PM
help with 350 bottom end build-up. flat top or .10 dome? cast hyper or forged? 74chevyflat Engine 5 11-03-2006 07:40 AM
3970010 sb build Trans am 91 Engine 3 09-14-2006 09:24 AM
