350 Build Cast #3970010 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-28-2013, 04:14 PM
NovaLou's Avatar
Trying to find out exactly what model chevy my block was originally in.
its a common casting #3970010 with:
010
020
184 or 164 near the oil filter.
I found H11 / 509 stamped on the 4 bolt back side but cant seem to find anything else other than a 512 / 532 on the front side.
does anyone know?
Old 05-28-2013, 04:39 PM
BOBCRMAN@aol.com's Avatar
Cast from 68-78. You will need the stamped numbers on the pass side forward deck surface for original application.
The Following User Says Thank You to BOBCRMAN@aol.com For This Useful Post:
NovaLou (05-28-2013)
Old 05-28-2013, 04:41 PM
NovaLou's Avatar
think I found them : J224 is what I can make out
Old 05-28-2013, 04:56 PM
NovaLou's Avatar
Does J224 mean October 22, 1974 ? How can I find or can I find the type of chevy it was in?
Old 05-28-2013, 05:42 PM
These guys should have vin info.
Mortec - Small-Block Engine Enthusiasts
Old 05-28-2013, 08:08 PM
techinspector1's Avatar
Wiki Edits: 326
The number Bob referenced is the suffix number, stamped on the block deck, passenger side, all the way to the front, in front of the head if there's one bolted to the block. This will normally include two or three Alpha characters which will tell you the origins of the motor.....scroll down here to "Suffix portion of Chevy engine code".
How to decode Chevy Engine Codes
Old 05-29-2013, 08:51 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
ID Chevy engines
350 Build Cast #3970010 NovaLou Engine 18 05-26-2013 10:10 AM
Chevy 350 Casting 3970010 misswriter415 Hotrodding Basics 13 08-23-2012 01:07 PM
327 Cast#3970010 70GMC_L/B_S/S Introduce Yourself 2 08-16-2007 02:53 PM
help with 350 bottom end build-up. flat top or .10 dome? cast hyper or forged? 74chevyflat Engine 5 11-03-2006 07:40 AM
3970010 sb build Trans am 91 Engine 3 09-14-2006 09:24 AM
