350 build. Need timing and edelbrock carb setup advice
Ok guys, please bear with me here as I'm sure the answers to both my questions are pretty straight forward but my right hand man who usually answers these questions for me is not available and my experience is limited.
I need to know what my timing should be set at (ballpark) also what jet/rod/spring combo I should start with in my carb. I am in SE Alabama at about 100 ft elev. The carb was initially tuned for 4000 ft elev in Montana. I had the engine running and tuned well there, but have since moved down south and lost my timing position. Also, does anyone have a desktop dyno program they can run this build on? I had one on my old computer and was unable to transfer the program to vista on my new computer and I made a few changes from my original build. Thanks in advance. So here is the build sheet: -SBC 350, 4 BOLT MAIN, BALANCED AND BLUE PRINTED, .30 OVER -SEALED POWER FLAT TOP PISTONS, -ALUMINUM PATRIOT HEADS, 195 CC RUNNER, 64 CC CHAMBER, 2.02 INTAKE, 1.6 EXHAUST, PORTED AND POLISHED (9.9 compression ratio total) -1.5 ROLLER ROCKERS -STUD GIRDLES -COMP CAM CL 12-211-2 (270H) Operating Range:1800-5800 RPM Duration Advertised:270° Intake / 270° Exhaust Duration @ .050'' Lift:224° Intake / 224° Exhaust Valve Lift w/1.5 Rockers:.470'' Intake / .470'' Exhaust Lobe Separation Angle:110° -EDELBROCK PERFORMER RPM INTAKE -EDELBROCK 1406 650 CFM CARBURATOR -1 5/8 TO 3” 4 INTO 1 HEADERS. -HEI IGNITION Another note; this 650 CFM carb seemed to work well at higher altitude, would it be benificial to change to a 700? I have one on the shelf if I need it. |
Haha, good point sir. I guess I like a silver bullet..
Thanks for the quick reply, I guess what I am really looking for is just a good ballpark to start. If I can I'd like to try to start somewhere close-ish to where I oughta be.
A good starting position would be to recalibrate the carb to box stock specs, and then tune from there. The timing, in MY opinion should be about 18* at idle and a total of 36* at 2800rpm. These specs are a good starting position and are going to be close.
generally most of the gm small block i've tuned on had total timing @32 to 36 degrees or even up to 40 if the cam is really large. Total timing is all of your vacuums plugged in where there suppose to be, engine warmed up to operating temp and rpm's @ 2000. As for your carb.. contact edelbrock about it and they will point you in the proper direction....
A edelbrock 750 will work a lot better. Start with stock jetting for the manual choke version #1407. Only minor tuning wil be required from the default tuneup when using the 750cfm Edelbrock carb. It will make more power than the 600.
The distributor can probabily use some work. Set the timing (max mechanical advance) at 36BTDC deg to start. Put some good gas in the tank. What are the vehicle details and the driving/tuning issue? Just for reference what is the jetting tuneup in the 1406 600 now? And timing details now? |
F-Bird: This is a 1950 Chevy pickup that I have been building for 4 years now. I have actually only driven it once, off of my trailer into my garage at my new place in AL(steep driveway, and I couldn't push it in). After I get a good idle tune, I will start driving and start working issues from there. As far as the current jet/rod set up in the 1406 I am not sure what it is. However I think I am going to take your advice and just swap in the 750 since I have it sitting there and it seems like the better choice anyhow. I will do the swap tomorrow evening, setting it to the default setup and check my timing. I will let you all know the status tomorrow evening. Thank you very much for the advice!
On the edelbrock I find that you can usually go 1 step leaner on the large section of the metering rods (the first two numbers) without much problems and it helps economy. On the 1406 this is not the case though as it is tuned lean from the factory.
BTW to get it truly dialed in you cannot just change the rods or the jets, you have to do both. Most people only do the rods as it is a lot easier (2 screws), but it severely limits your tune. With a larger cam you can probably step down a notch on the springs too as your vacuum will be lower. For timing the already recommended 18 initial 36 total is a good place to start. If you want to really get fancy you can tune the secondary air door by adjusting the balance of the weights- but this can be a little tricky. Tuning the accelerator pump is a bit trickier than a holley, start with the stock setup, again, I usually find you can move the arm in to go a hair leaner, and you can get different sized squirters from Summit to tune how fast it comes in. |
Thanks for all of the help guys!
I set my timing to about 16 deg before adjusting my carb. I went online and found the instructions for tuning the idle. After a little head scratching and finding out I had a loose clamp on a heater hose I got everything dialed in. I then adjusted my timing to 18 deg (mechanical) and gave it a couple good revs, it picked up immediately with no hesitation and hit 4k RPM in a hurry. It has a smooth steady idle at 700 RPM. After all of that fun I couldn't stop there, The header gasket blew out after I started it (I recently put on new Hedman long tube headers) I couldn't let it sit like that so I pulled it off and went with the standard manifold gaskets and it worked like a charm. whew! Doesn't sound like much but all together it took me about 5 hours. Those headers don't go on or off easily. Again thanks for all of the help, I was able to approach the job with a little more confidence.
| Edelbrock Performer Cam Timing Wrong | hotrodtodd1968 | Engine | 13 | 06-03-2012 09:43 AM |
| Hi all I took your carb advice to heart need to know a little more | ghomer | Engine | 18 | 09-05-2010 06:58 AM |
| installing distributor/timing on sbc 350 | 075turbo | Hotrodding Basics | 38 | 05-19-2010 07:33 AM |
| 350 Chevy 1st build, need advice. | monzter | Engine | 16 | 07-19-2009 07:10 PM |
| Edelbrock carb: Metering rods & jetting appropriately for altitude | 04SilveradoMykk | Engine | 8 | 04-28-2009 04:55 PM |
