Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350 build questions, looking for 300-350 hp
Old 06-22-2011, 05:43 PM
Jaiden2010 Jaiden2010 is offline
I found this today for $125 I pull. Not sure if it's a 305 or 350, I can't see the casting numbers on the block. The heads are 10125320. I have no idea if it runs, it's a as is deal. I am going to build a fresh motor, as long is not junk inside maybe this is a better bet. I found it under the hood of a 60's chevy. I don't plan on running any fuel injection/computer in my S-10. I am going to run a carb. I am not skilled in playing with wiring etc. The engine harness and computer is there however. The transmission is gone. The motor is just sitting in the engine bay. Here are some pics I took with my phone and emailed to myself so excuse the quality.
Somebody did a lot of work to this Suburban it has a late model instrument cluster, late model 5 lug disc brakes, late model tilt, ABS module/setup. Looks like they just never finished the engine install. all the wiring is unplugged as with some of the fuel rails/injectors are out. Unless it happened at the yard?
ID:	56285   Click image for larger version
ID:	56286   Click image for larger version
