350 Chev Compression ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-21-2003, 10:15 AM
Recently purchased a car with a chev 350 and am trying to determine compression ration in order to choose a cam. It's a '71/'72 motor with fuelie heads/64cc chambers and flat-top pistons. Motor has about 10K since rebuild and previous owner doesn't know much more about it than what I told you. Current cam is stock.
Anyone know how I can determine compression ratio without pulling the heads?
Scott
Old 09-21-2003, 10:23 AM
Bumpstick's Avatar
Hammer and a torch
Use the head casting numbers and determine the chamber size (64-...?) cc... And then you can determine a close ratio... If the pistons are true flat tops w/4 valve reliefs it makes it easier to figure...
Old 09-21-2003, 11:26 AM
I have identified the heads as having 64 cc chambers but can't tell if the pistons are true flat-tops without pulling a head.
Scott
Old 09-21-2003, 11:40 AM
Rubberman2003's Avatar
What is the number on the block? Oh wait are they stock pistons? oppsy...if they are just us the block numbers and i think you can find the CR on the net.
Old 09-21-2003, 01:31 PM
New Member
compression testers are fairly cheap to buy id try that or borrow one like i do
Old 09-21-2003, 01:51 PM
What kind of numbers should I see with a compression tester. Is there a range that corresponds with 8.75:1 to 9.0:1, 9.0:1 to 9.25:1?
Scott
Old 09-21-2003, 01:55 PM
New Member
screw it in the spark plug socket start engine and run it...needle will go to what your compression is
Old 09-21-2003, 02:20 PM
It's probably around 9.5:1 - hard to say without more specs. No, a compression test can't really tell you.
Old 09-21-2003, 02:25 PM
I know how to use a compression tester, what I don't know is once I take the reading how do I relate that number to a compression ratio.
Scott
Okay, thanks for everyone's input. I think I better pull one of the heads to see what kind of piston I have and measure the deck heigth. Don't want to end up with a cam that requires a certain compression that I don't have.
Scott
