Guys. I've been trying to fix an annoying 'cutting-out' fault which happens under load with my 32 sedan, which I've traced to the gas supply. I'm running a crate SBC (basic spec) with Edelbrock Performer inlet and carb (all clean), with a Mr Gasket mechanical fuel pump (no problems here). Done only 2000 miles since I build it.
I think the culprit is my in-line fuel filter causing too much obstruction. I'm using alumium hard lines with AN fittings and an Earl's in-line aluminum filter with a sintered bronze element, between the tank and the pump. The filter element has got dirtier and despite cleaning in gas its looking a bit clogged after my first 2000 miles. Looking at the Earls catalog again it says the filter is good for only 4 or 5 gallons per hour-which seems low. Taking the element out seems to give loads more gas. Here's my questions-
How much fuel per hour would a small block demand when its pulling hard?
Does a mechanical pump work on suction or pumping? - ie does it need a free flow siphon effect out of the tank, and then blasts it up to the carb??
I think I need less restriction in the tank-to-pump line. Can I safely lose this rear filter and just have one after the pump before the carb? or should I go for a simple mesh filter at the tank end to keep the big stuff out of the pump?
Maybe I should expect to replace the mesh pretty often, or maybe just this once now the build-up muck has come through the system?
I'd be grateful for your advice, thanks guys
Limey Simon
