350 chev, head gasket - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2007, 12:48 PM
I was getting ready to put the heads back on my 355 chev and I noticed the wholes for the cooling water are smaller on head gaskets in the center, also the year is 1974, should I get diff. head gaskets Thank you
Old 02-13-2007, 12:51 PM
poncho62's Avatar
Wiki Edits: 5
Thats normal.........all SB head gaskets will have those size holes
Old 02-13-2007, 01:32 PM
head gasket
Thanks for the information on the small block head gasket .My motor is a 74 ,is the head bolt torque 65 lbs
Old 02-14-2007, 10:59 AM
fast68's Avatar
likes chevy trucks & boobies
all sbc are 65 yes
http://www.boxwrench.net/specs/chevy_sb.htm
Old 02-14-2007, 06:45 PM
What gasket are you using
Old 02-14-2007, 06:51 PM
brian0605's Avatar
mostly confused
Last journal entry:
poncho62 is right, bolt them up and torque'em down!!! Brian
Old 02-15-2007, 10:44 AM
johnsongrass1's Avatar
Race it, Don't rice it!
CNC is correct,
The gasket maker and bolt maker determine the needed rotational torque.
'65 6 cyl. Mustang Head Gasket Problem 68Ranchero General Rodding Tech 6 04-27-2005 12:20 PM
3.8 Ford Head Gasket Questions RCastle Engine 17 04-11-2005 10:14 AM
buy a used engine vs. replace head gasket? andrewpruitt Engine 8 03-21-2005 05:52 PM
Longblock Chevy 350 Crate: Cam and Head concerns 360Camaro Engine 18 08-05-2003 03:51 PM
head gasket question RiceMuncherdude Engine 2 03-12-2003 03:01 AM
