350 chev wont start, just backfire - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-24-2008, 11:30 PM
G'Day hoping someone can help me with little issue im having with my vehicle.
Problem:
Engine is backfiring through carby or exhaust instead of starting. Been thru timing and can't find a fault (maybe I missed something).
Vehicle setup:
350 chev with mild cam
750 double pumper (holley)
Procomp electronic distributor
MSD coil
This problem has started since fitting a NOS plate kit, could the issue be with this????
Thanks in advance for your time helping me out.
Cheers,
Waza
Old 06-25-2008, 12:01 AM
Backfiring through the carb or exh sounds like a timing issue to me. Did you change anything timing wise when the nitrous kit was installed (like rotating the distributor)? Have you verified your ign timing with a timing light? Check over you vacuum advance if equipped. Also check the mechanical advance. I was thinking about all the basic timing issues that might cause this.
Hope this helps some
BigBuick Joe
Old 06-25-2008, 01:09 AM
techinspector1's Avatar
Wiki Edits: 326
Check the NOS plate for a big hole missing a plug. That's just a guess. Or maybe a big hole in the rear base of the carb that's missing a connection or plug.
Chev LT1 350 engine front accessory clearance haysbo Engine 2 09-02-2007 07:13 PM
69 Chev 350 block has a distributor bushing? baddbob Engine 1 06-22-2007 04:22 PM
chevy 350 won't start Troy Smedley Engine 2 03-23-2007 05:21 AM
My truck wont start. 91 serria 350 tbi montea Engine 17 12-17-2006 04:23 PM
Big chev 454 and small chev 350 bolt pattern boneyard Buick Engine 4 01-18-2006 09:07 PM
