350 Chevy Buggy Project - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-05-2010, 01:30 PM
Hello everyone, I am new to constructing vehicles from the ground up, but I do have some experience with motors. I am planning on going big and buying a refurbished 350 chevy for a buggy project. I wanted to complete the motor and radiator first and then proceed to create a simple transmission for it. Firstly, I came across a coupler that mounts onto the flexplate/flywheel bolts and can drive a 10 spline shaft directly. Is it possible to fabricate/obtain a gearbox that can handle the power and controll just engage/disengage for the motor? If it is, are there any transaxles that can also withstand torque from a stock 350? I also would like to ask if a frame from a go kart can be beefed up alot with steel colums and supports, and heavy duty wheel bearings to support a small block motor? It's almost like a v8 barstool, and i have seen a few of those. Any information would help.
ID:	47889   Click image for larger version
Old 09-05-2010, 03:34 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
Just use a clutch to disengage the drive. A set of bearings will be needed to keep the splined shaft aligned in the clutch disc.
A Borg Warner (velvetdrive) is forward, reverse, neutral marine transmission that can easily handle stock SBC.
I would look for used or rebuilt as these have been around a long time.
Corvette has be using a transaxle for many years. Need to some research on that.
Putting that engine in go-kart is funny but you never use more than 5% of the power.
Here is your car!!!! www.sandrocket.com
Old 09-05-2010, 04:27 PM
thats all the power you need with that weight
Old 09-05-2010, 04:28 PM
ericnova72's Avatar
More for Less Racer
A shorty Powerglide might work the best and be the cheapest and easiest to use. A shorty is used in bracket racer dragsters, it is a kit that replaces the tail shaft and tailhousing with a short 2" or so pieces.
No, a go-kart frame won't do it, too thin wall tubing, wheelbearings/spindles/axle are all not up to handling that much weight(550lbs). You need to be looking at a minimum of 1-1/4 to 2" diameter .095" wall thickness mild steel tube(or .065" wall chromoly) for the frame.
Olds Toronado and Buick Riviera used a TH-350 based transaxle in the late70's/early 80's.
Hi. just wondering why the 350 chevy small block is so good... judgedredd Hotrodders' Lounge 78 06-25-2010 09:01 AM
350 chevy help joesnova2 Engine 7 11-08-2009 06:46 AM
buick 350 - chevy 350 72buick Engine 23 10-13-2009 09:38 PM
El Camino Engine - 350 Chevy or 455 Pontiac bjam2 Engine 16 08-07-2007 04:45 PM
El Camino Engine - 350 Chevy or 455 Pontiac bjam2 Engine 17 01-06-2007 10:11 PM
