350 chevy compression estimate please !!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-17-2006, 10:20 PM
I recently had my chevy 350 rebuilt ,and im getting conflicting estimates on its actual compression ratio,i'm wanting to put a bigger cam and possibly aftermarket heads on it, but im unsure of its compression at this point. i tried the conversion tables on the kieth black site, but i had to be doing something wrong anyway, its a 350 bored 40 over with 75cc 993 heads .the block was not decked and it has flat top pistons that say compression would be 10.2:1 with 64cc heads but i have 75cc most quotes i see are for 76cc heads the pistons are speedpro 345np40 cast pistons also the headgaskets came in a basic rebuild kit from r o l ,i think.thanks in advance
Old 08-17-2006, 11:00 PM
Your a shade over 9:1.
Old 08-17-2006, 11:12 PM
thanks thats what the machine shop said but others told me as low as 8.3
Old 08-18-2006, 12:34 AM
malibu68's Avatar
i downloaded a virtual engine calculator, that helps with anything like this, so just google it
Old 08-18-2006, 02:18 PM
I'm thinking 8.7:1 cr with 76cc heads.
Cylinder volume = 730cc
piston dish volume = 6cc (4 relief, spec'd in summit catalog)
head gasket volume = 9cc
piston below deck volume 0.015 = 4cc
Cylinder head volume = 76cc
(730 + 6 + 9 + 4 + 76) / (6 + 9 + 4 +76) = (730 + 95)/95 = 8.68
And 9.8:1 cr with 64cc heads
(730 + 6 + 9 + 4 + 64) / (6 + 9 + 4 +64) = (730 + 83)/83 = 9.795
Summit says 9.72:1 with 64cc with a +0.030 bore. A +0.040 bore will increase the compression a little over a +0.030 bore.
Old 08-18-2006, 03:27 PM
But the heads are 75cc not 76cc heads ,and the pistons i have are advertised in jegs as speed pro cast pistons 345np40 ,not the hypers and it says in the desription 10.2:1 with 64 cc heads thats why i bought these instead of the hypers because the were advertised with slightly more compression. im hoping to have atleast a 9.1 motor because i want to upgrade to a bigger cam it has a lunati 00016 now with 218 dur 458 lift i was wanting to go with a magnum 270 or 280 by comp cams and eventually some aftermarket heads but for right now just a cam change.also the piston are supposed to be 5cc valve reliefs
Old 08-18-2006, 03:53 PM
Ok, 5cc piston reliefs and 75cc heads.
Now I'm thinking 8.85:1 cr with 75cc heads.
piston dish volume = 5cc (flat top w/4 relief, spec'd in Jegs catalog)
piston below deck volume 0.020 = 4cc
Cylinder head volume = 75cc
(730 + 5 + 9 + 4 + 75) / (5 + 9 + 4 + 75) = (730 + 93)/93 = 8.85
And 10.0:1 cr with 64cc heads
(730 + 5 + 9 + 4 + 64) / (5 + 9 + 4 +64) = (730 + 81)/81 = 10.0
You could get 10.2:1 cr with 64cc heads if the piston was only 0.010" under the deck. The amount the piston is under the deck makes a pretty big difference in compression ratio. For example, if your block was zero decked, the compression would be 9.2:1 with the 75cc heads and 10.5:1 with the 64's. 0.020" below the deck is about the norm.
Old 08-18-2006, 08:47 PM
Thanks to all that replied, If in fact this is a 8.85 :1 motor is that enough compression for either of those cams, i thinking about putting some World Product heads on it to raise the compression a bit, for a bigger cam and added performance,But if what i have know will work, ill use that money for my posi and gears.THANKS
Old 08-19-2006, 09:09 AM
I like this one.
http://www.csgnetwork.com/compcalc.html
Old 08-21-2006, 07:08 AM
Should be able to run a 270H with 8.9:1 cr. Yes, spending money on a posi will be a good idea. A bunch of hp doesn't mean much if you can't stick it down on the street.
Hi. just wondering why the 350 chevy small block is so good... judgedredd Hotrodders' Lounge 78 06-25-2010 08:01 AM
350 chevy help joesnova2 Engine 7 11-08-2009 05:46 AM
El Camino Engine - 350 Chevy or 455 Pontiac bjam2 Engine 16 08-07-2007 03:45 PM
1978 grand prix chevy 350 swap threesand9s Engine 10 06-29-2004 12:43 PM
85 chevy 305 heads on an 89 TBI chevy 350? jazzguitar Engine 4 11-03-2002 04:11 AM
