350 chevy coolant problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-20-2012, 01:07 AM
1996thunderchicken's Avatar
ALL AMERICAN MADE
i was driving tonight after flushing the coolant system and i let it idle at the gas station for about 5 mins and the temp stayed at the usual 200 degrees but then i went to go home from the gas staion and she shot up past 245 degrees and right back down to 200, the systems flushed the level is full what would cause this please i need help thank you.
Old 07-20-2012, 09:09 AM
1971BB427's Avatar
Sounds like it might have an air pocket. Let it cool down and check the level again. Might need a air bleed hole drilled in the T stat to get rid of the air pocket.
'73 Olds 350 Oil in coolant no coolant in oil :( DQ81 Engine 4 09-28-2011 07:46 PM
coolant/ heater chevy 350 jeepers creepers Engine 7 01-02-2010 04:51 PM
Coolant Dilemma! Ok to use Green coolant with Red coolant? mgold Hotrodding Basics 6 03-31-2009 04:37 PM
coolant problem untchable502 Engine 9 06-09-2008 04:02 AM
Coolant problem solved, but why? Madd Syntst Engine 3 09-16-2003 11:36 AM
