-   -   350 chevy engine (http://www.hotrodders.com/forum/350-chevy-engine-230356.html)
wingman_g 03-05-2013 12:57 PM
350 chevy engine
the 350 in my hot rod is blowing oil,the dipstisk is on the right side or passenger side,when do you think that the engine was made?I want to replace the block ,is there any difference in the block between 1980 and 1985,I will have to reuse all the componates from the present engine,which also has vinage air,so I need to make the right choice:welcome:
327NUT 03-05-2013 02:44 PM
This question needs to go in the basics or engine section.
T-bucket23 03-05-2013 03:10 PM
Moved to engine
455olds 03-06-2013 07:21 AM
I think the first major change happened in '86 or '87. Any block from the early '70s till '85 should have all the same accessory mounting holes you should need.
RWENUTS 03-06-2013 07:41 AM
Wadda ya mean "blowing oil"?
Could be you need a working pcv instead of a new motor!!
