350 chevy engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-05-2013, 12:57 PM
350 chevy engine
the 350 in my hot rod is blowing oil,the dipstisk is on the right side or passenger side,when do you think that the engine was made?I want to replace the block ,is there any difference in the block between 1980 and 1985,I will have to reuse all the componates from the present engine,which also has vinage air,so I need to make the right choice
Old 03-05-2013, 02:44 PM
327NUT's Avatar
This question needs to go in the basics or engine section.
Old 03-05-2013, 03:10 PM
T-bucket23's Avatar
Wiki Edits: 26
Moved to engine
Chet
Old 03-06-2013, 07:21 AM
455olds's Avatar
I think the first major change happened in '86 or '87. Any block from the early '70s till '85 should have all the same accessory mounting holes you should need.
Old 03-06-2013, 07:41 AM
RWENUTS's Avatar
Wadda ya mean "blowing oil"?
Could be you need a working pcv instead of a new motor!!
The Following User Says Thank You to RWENUTS For This Useful Post:
1Gary (03-06-2013)
chevy 350 engine tbrown8338 Engine 1 01-21-2013 09:05 AM
Chevy engine ID, can anyone help id my 350 engine? Ron Garcia Hotrodding Basics 23 01-31-2008 03:51 AM
350 chevy engine finley2005 Engine 1 10-15-2006 01:29 PM
Chevy 350 Engine & Trans in a 46 Chevy Pickup Warner Engine 4 02-11-2005 04:44 PM
350 Chevy Engine Doug Goolsby Introduce Yourself 1 10-02-2004 07:45 AM
