350 chevy engine burning oil - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-17-2011, 05:24 PM
Hi to Everyone, my 350 chevy engine has a 400 turbo transmission,recently
it began to smoke and burn oil, I was told it could be the modulator in the transmission , have replaced the modulator but it still smokes and uses engine oil, checked the crank case vents in the rocker arm covers and their all clear and working properly , engine does not have excessive back pressure in crank case vents . Do not know why it is burning engine oil, can you give me help on this ?
Thanks, Bill
Old 11-17-2011, 06:37 PM
techinspector1's Avatar
Wiki Edits: 326
What does the tailpipe look like?
Old 11-17-2011, 07:19 PM
Is it a high mile motor?
Old 11-17-2011, 07:28 PM
gmc1990rodder's Avatar
Sounds like time for a re-build.
Old 11-17-2011, 07:30 PM
406 bug's Avatar
9.82 @ 139mph
Time for a leak down to determine condition of rings/valve guide/seals
Old 11-17-2011, 10:29 PM
Thank you all for the come back, the tail pipe is dark but not oily and don't know how many miles are on it. is it possible the fuel pump could be sucking oil from the crank case into the fuel ?
Old 11-17-2011, 11:39 PM
could be a number of things.cheek your plugs for any noticable fouling.a dry or damaged vavle stem seal.i would get a test done on cylinders first,if its a oil ring on one cylinder you can slip the head off without taking off the maniflod and push that piston out.good luck dude
Old 11-18-2011, 12:07 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Originally Posted by kuta1972
.... you can slip the head off without taking off the maniflod and push that piston out.good luck dude
You don't mean without removing the intake manifold do you?? I would think real hard about that one if it was me, the intake is so easy to remove, why fight it?
Semper Fi
Old 11-18-2011, 12:53 AM
i have done it this way in the past to save time.depends on what sort of time you wont to put into it.if it was me i would pull both heads to check cylinders and fresh gaskets.but as a quick fix by slipping head out you dont have to mess around with dizzy,kickdown etc
3400 gm engine burning water, fast68 Engine 11 03-22-2010 07:28 PM
383 engine tapping and oil burning- weird RowShan Engine 15 10-10-2009 06:07 PM
Hydrogen Burning Engine, no gas storage... Cyberats Hotrodders' Lounge 101 01-29-2009 08:16 PM
Burning sound coming from engine heath_15_4567 Engine 5 11-11-2005 02:41 PM
