350 Chevy engine combo help ! - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-30-2010, 03:49 PM
ericnova72's Avatar
More for Less Racer
The Comp Magnum rockers 350 lb limit is max open pressure allowed, not max spring rate allowed, the Isky springs is 320lbs open so it is under the limit. The Howards spring is nearly the same, so you have no worries there.
I'd probably use the TM-1 on the smaller engine and try it, if it didn't run the way I thought it should then try a Holley Strip Dominator or Weiand Team G.
The 327 will just make slightly less power than the same parts in a 350, just because it has fewer cubes. Expect the stall to be a little lower due to the engine having less torque. You'll definately want to rev it into the 72-7300 area for the shift point.
I'd stay with the same camshaft ideas you have been looking at, they will have a little higher powerband than listed as listed values are based off of 350 cubes. This works out fine since you are going to have to rev it up to really get into the meat of the power anyway due to the short stroke and small cubes. Good thing you do have that 8" converter, now you will really need it.
Got a casting # off the block?? Wondering if this is small journal or large journal. Would be a very good idea to have ARP bolts put in the rods and have them resized if they don't already have them.
  #17 (permalink)
Old 08-30-2010, 06:27 PM
That's grate to hear Eric, Fantastic to get things straight about these rocker arm's
This engine is based on a 4 bolt 350 Block, so it's large journal, I will check the rods sometime this week
It's also nice to hear that it's do-able making some power with these little cubes !!!
Monzter.
If you do not want to register, fill this field only and the name will be used as user name for your post.
Chevy engine ID, can anyone help id my 350 engine? Ron Garcia Hotrodding Basics 23 01-31-2008 03:51 AM
Chevy 350 to 400 trans combo Rockey Meo General Rodding Tech 5 09-14-2006 02:46 PM
what cam/intake combo, rebuilding chevy 350 30 over 73camaro Engine 2 08-02-2006 12:22 PM
Chevy 350 "K" engine tbi ???? k-star Engine 6 08-25-2005 11:23 PM
350 chevy engine we2nutsinahouse Engine 3 06-15-2002 06:45 PM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
