Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350 chevy final touches
Old 06-03-2012, 06:30 PM
monzter monzter is offline
I also have a set of cast iron heads #624 that i could use, to get sone low end power. because the aluminum heads might be to big for the street. If i would use these cast iron heads i would need to mill them to get similar compression ratio as i would with them 64cc heads. Does anybody know how much milling is needed to shave off 1cc ?
