350 chevy head /cam combo? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2006, 08:20 PM
i have a street rod with a stock 74 350 chevy that i've run for a while.i want to change the smog heads to a "041" or similar type high performance type.the stock cam is described as the "old 292" cam that came in 300 h.p. 327.it's described as a "good street cam".i wondering if i should use this cam with the new heads, or switch to a different cam.keep in mind,it's a street driver that i'd like to occasionally race, so i would like to keep a good smooth idle and decent gas economy.i'm using a turbo 400 with stock torque converter,and a 12-bolt chevy rear with 3:55 gears.thanks for any info
Hi. just wondering why the 350 chevy small block is so good... judgedredd Hotrodders' Lounge 78 06-25-2010 08:01 AM
350 chevy help joesnova2 Engine 7 11-08-2009 05:46 AM
305 head on 350 savman1 Engine 4 10-15-2006 09:18 PM
SBO 350, Head Gasket help, with photos 360Camaro Engine 5 07-11-2005 08:29 PM
350 buick in chevy truck? jrm123180 Engine 7 04-03-2004 11:03 PM
