-   -   350 chevy ID (http://www.hotrodders.com/forum/350-chevy-id-227132.html)
walvarado 12-13-2012 10:11 AM
350 chevy ID
I just purchased what is said to be a 1984 corvette short block. The block is standard bore but the piston tops are flat with a wide two valve relief? I thought most small blocks of that era were dished with 4 valve reliefs? The numbers on the front right pad are V0727ZFK 1ES148454. Casting number 14010207. Any one that can give some help on this would be greatly appreciated. Thank you.
gearheadslife 12-13-2012 10:33 AM
nothing special 84's where crossfire..
standard 350 sbc cast crank/ standard rods, cast pistons..
