350 chevy ID - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-13-2012, 10:11 AM
350 chevy ID
I just purchased what is said to be a 1984 corvette short block. The block is standard bore but the piston tops are flat with a wide two valve relief? I thought most small blocks of that era were dished with 4 valve reliefs? The numbers on the front right pad are V0727ZFK 1ES148454. Casting number 14010207. Any one that can give some help on this would be greatly appreciated. Thank you.
Old 12-13-2012, 10:33 AM
Banned
nothing special 84's where crossfire..
standard 350 sbc cast crank/ standard rods, cast pistons..
The Following User Says Thank You to gearheadslife For This Useful Post:
walvarado (12-14-2012)
78 firebird with a chevy 350 and T-350 neutral start only addictivewoodworks Transmission - Rearend 3 03-15-2012 06:11 AM
The difference between Pre 86 chevy 350 and post 86 350's haaslyd Engine 12 12-15-2011 08:37 PM
72 Chevy pickup, 350 with t-350 is the trans slipping Mertz Transmission - Rearend 3 03-20-2011 05:27 PM
DEBATE: Which heads are better?....Chevy 350, Pontiac 350, Olds 350 or Plymouth 350. Steve-0321 Hotrodding Basics 21 11-26-2007 12:44 AM
53 Chevy 350/350 starter won't turn over tm454 Electrical 6 07-15-2003 04:40 AM
