350 chevy into 1952 Chevy truck
whaz-up fellow street rodders!
In my 1952 3/4 ton pick-up I would like to place in a 350 engine pushing no more than 400hp along with a turbo tranny, the thing is I really want to keep the stock suspension and up grade to disc-brakes and repack the rear end. I do not care about new cross member at all as long as I get decent ride and braking for a 50yro+ truck and that the engine do not throw out the rear-end could you street rodders help me out with some advice please. |
Welcome to Hotrodders.com Those year trucks are getting real popular lately. 1) installing the 350 engine will be no problem 2) I suggest finding and using a 700R4 or a 2004R overdrive transmission instead of the Turbo tranny to gain the Overdrive. 3) That year truck has a enclosed driveshaft ... I believe ... so issues will arise trying to use the 350/automatic transmission because they use a exposed driveshaft. Go here for a list of donor rear ends ... http://carnut.com/specs/rear.html I would use a 9 inch Ford ( but I always do ... whatever I work on ) But a original, stock 55 to 59 Chevrolet 1/2 ton rear end could work. They have 6 lug wheels and a 3.90 or 4.11 rear end ratio ( great with the Overdrive 700R4 ) 4) For the front brake conversion to disc ... I do not have a suggestion. Hopefully one of our members has done that Again WELCOME to Hotrodders.com Deuce ... Moderator
If you want to keep it all GM then any mid 70's Camaro or Firebird 10 bolt will fit perfectly.
This is my '53 and it has a 78 Firebird 10 bolt with 3.08 gearing. |
Here's a link for a disc conversion from Brothers. There's probably info for a power booster if you look around or if you even want one. Also, since it's a 3/4T, make sure the brakes in the link are not for a 1/2t. Just a thought to make sure you don't under size them. Or maybe it will work for both. Good luck, John
http://www.brotherstrucks.com/prodin...number=NOFX559 |
| Recent General Rodding Tech posts with photos |
| DEBATE: Which heads are better?....Chevy 350, Pontiac 350, Olds 350 or Plymouth 350. | Steve-0321 | Hotrodding Basics | 21 | 11-26-2007 12:44 AM |
| Turbocharging a 350 chevy | radracer43 | Engine | 4 | 09-25-2005 07:30 PM |
| 94 chevy truck maybe dist./ignition problem,please help! | bluesmanjesse | Engine | 14 | 11-19-2004 03:31 PM |
| Switching from olds 350 to chevy 383... and now I've got problems matching up trannys | elukas | Transmission - Rearend | 6 | 08-26-2003 12:03 PM |
| 82 chevy truck upgrade to 350 questions? | damon18a | Engine | 4 | 02-12-2003 03:12 AM |
