350 chevy lifter failure
lifter is making a ticking noise
Looking for procedure on how to replace |
take off the valve covers, take nut off of rocker arm, take off rocker arm, pull push rods out, tip block up side down and they should fall right out but make sure you empty the coolant and oil out first before you tip it upside down
There are other reasons to have a noisy lifter. Readjust it first. If that doesn't help, check that there's no problem w/the spring being damaged, that the rocker arm or valve tip isn't worn, and the push rods is straight then go on to the lifter itself. If you can for sure locate which lifter is the culprit, remove just it and take it apart after determining the cam lobe and lifter foot are not overly worn, clean everything in solvent, dry, re lube w/motor oil and reassemble it and reinstall the lifter in the exact same hole it came from. Before dropping the lifter in place, lube the "foot" of the lifter (not the body- just the bottom, or foot) and the cam lobe (use a paint brush that will fit down the lifter hole) w/moly cam lube. The body of the lifter gets motor oil. Readjust the lifter on the base circle of the cam and w/luck, you'll be good to go. Good luck. |
sticking valve too...
i had the exact same problem... changed all the lifters and shortly afterwards it started again.. i figured the only thing i didn't do want re-do the heads... did that and no more problems.... if u deside to replace the lifters??? before u put them in, put the primer into the oil pump and ck oil flow.. u'll get oil on the drivers side, the put in lifters and do it again for the pass side.. oil should gush out of the rear lifter holes of cyl 7 and 8.. don't forget u need to put lifters in the drivers side to get oil to the pass side..
| Stuck Lifter Plungers on '76 Pontiac 350 | Bigolotava | Engine | 8 | 07-01-2011 09:56 PM |
| 350 chevy help | joesnova2 | Engine | 7 | 11-08-2009 05:46 AM |
| 350 or 383 for 1963 Chevy Truck | abeis | Engine | 6 | 03-12-2009 02:19 AM |
| Need Help FAST!!!!!!!!!! | millertime85 | Engine | 14 | 06-25-2008 07:01 PM |
| El Camino Engine - 350 Chevy or 455 Pontiac | bjam2 | Engine | 16 | 08-07-2007 03:45 PM |
