Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350 chevy motor
Thread: 350 chevy motor
Old 11-22-2001, 11:33 AM
Studebaker Studebaker is offline
Post
Well it could be numerous things, first check the timing, if the timing is somewhat off and it doesn't idle very good and backfires slightly, the timing chain may have jumped a tooth. Chevy small blocks are also notorious for flat cam lobes, this can be checked by removing the valve covers and checking the lift at the rockers when manually turning the engine over. However before checking any of this, start with the basics, check the manifold and carb for any major vacuum leaks. Vacuum leaks will cause a bad idle and also slight backfire at acceration. Did this condition happen all at once or gradually?, if it happened all at once, I would bet on a jumped timing chain. GOOD LUCK!
