350 Chevy Oil Filter Adpater question - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-11-2007, 05:31 PM
I am rebuilding my 350 sbc engine, and when I took the block to the machine shop, I thought I remembered a seal or gasket around the outside edge of where the oil filter adapter bolts on. I called the machine shop about it, but he said that a 2 piece rear main block does not have a gasket for the oil filter adapter, it bolts metal to metal. I also went to the local chevy dealer, (lost cause) and they could not find a gasket or seal for it either. Can anyone confirm if the machine shop is right?
Old 01-11-2007, 06:45 PM
The shop is right. I have a 327 SBC with the same adapter. The seal is the neoprene ring that goes around the inside if the lip when you change the oil filter.
Old 01-11-2007, 07:31 PM
A factory adapter doesn't use a gasket. Some aftermarket oil filter adapters use a rubber seal around the outside of the adapter base where it contacts the block. It's about the same diameter as a spin-on filter for a SBC. Here's a pic of the TransDapt version from Summit's site:
Old 01-11-2007, 09:25 PM
I was thinking that the block had a gasket around the outside edge. Since this is the original adapter and flange, do I need the see about finding the gasket, or just go without it?
Old 01-12-2007, 05:10 PM
It sounds like you want to have a gasket where none is needed. Ok, use a neoprene O ring from an oil filter. That will fit it perfectly.
Old 01-13-2007, 09:27 AM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
the stock 283-327 filter base uses a rubber oring around the out side of it. That oring comes with a new filter. Go buy the canister type filter and there should be a new oring in the box. That oring seals the can against the block.
http://www.partsamerica.com/ProductD...type=1&ptset=A
I can't figure out how to post a picture here is a link to a picture of what you need.
Old 01-14-2007, 05:37 PM
Thank everyone very much for the information. I will go and purchase the canister filter tomorrow.
This is a great site!!!!
Old 01-15-2007, 11:19 AM
Last journal entry: It's getting there
350 Chevy oil filter adapter
I just put a 350 crate in my '41. No gasket needed on adaptor. Used OEM adapter. Seal is provided by Oil Filter.
Chevy 350 low oil pressure @ 3500 RPM tjmr2 Engine 17 12-25-2006 07:53 AM
87 Chevy 350 TBI rod & main Clearance question Mustangsaly Engine 3 05-20-2006 04:18 PM
Oil filter Question. HemmiGremmie Engine 1 03-04-2006 03:48 PM
oil and compression ring position 350 chevy 72 chevy elcamino Engine 7 02-16-2004 04:19 PM
Oil pressure on 350 Chevy BigMac Engine 9 09-13-2003 10:01 PM
