350 chevy, oil pressure drops to zero when warm - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-20-2012, 09:05 AM
1971BB427's Avatar
Had a similar issue twice. Once it was because I was young and green, and rebuilt my engine, but decided to leave the cam bearings in. Did the exact thing your's is doing.
On another build I had the engine machined at a shop and they installed new cam bearings, and got the wrong rear bearing in. It bled down pressure and my oil pressure readings were low at idle and cruise, and even lower once warmed up.
Both cases required new cam bearings to fix the problem.
  #17 (permalink)
Old 07-20-2012, 04:54 PM
i checked the gauge with a mech. s.w.gauge,i pinned oil pickup .ihave some oil at rockers at idle hot ,when gauge reads o,so iamjust going too drive it. thanks for the info.hotrodthug
  #18 (permalink)
Old 07-21-2012, 04:44 AM
Richiehd's Avatar
JS-70
OK so that wont last long before you wipe out the front main or wipe a couple lobes off the cam.
  #19 (permalink)
Old 07-22-2012, 04:29 AM
CNC Blocks Northeast
Originally Posted by cobalt327 View Post
The diagram of the plug and measurements and its location is from HERE. By examining the diagram, you can see that the oil pressure shouldn't be lost if the plug is left out.
If the plug is driven in too far (blue circle), that's a different story.
Looks like have some more BS about loosing pressure with out the plug under the main cap.
Here is some factual or real info from real engine builders not book reader or some who does not know how SBC oiling system works LOL.
PLUG UNDER REAR CAP • Speed Talk
If you can read look this over
  #20 (permalink)
Old 07-22-2012, 08:34 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The pressure will not be lost if the plug is omitted!!! That's why the drawing above was posted. If you carefully examine the drawing, following the arrows and paying attention to what galleys lead where, you will clearly see the oil pathway, and you can also tell how driving the plug too deep is worse than leaving it out- although leaving it out is not correct, either.
Chevy 383 stroker oil pressure drops at w.o.t idle and curise is find Danny Scott Engine 6 04-05-2012 03:24 PM
oil pressure drops after warmup Nova68Chevy2 Engine 11 10-29-2011 08:28 PM
chevy 350 oil pressure drops to zero bel52air Engine 69 09-28-2011 11:50 PM
Oil pressure drops to near zero, warming up firstgenbird Engine 5 03-31-2005 02:17 AM
Oil pressure drops gilliganspl Engine 8 09-03-2004 09:28 AM
