Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350 chevy pistons
Old 01-29-2010, 08:20 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by butchfig8
what is the secret for pressing wrist pins & piston onto rods,
a couple i have done seam tight
My machine shop uses heat to expand the pin end of the rod so the pin fits relatively easily into position. This has to be done in a deliberate fashion- if you don't get the pin positioned correctly, you have to press it back out and start over.
If you're doing it cold , you need to have the correct fixtures to avoid damaging the piston or pin/rod assembly. Frankly, I wouldn't advise this.
