Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350 Chevy power steering
Old 09-21-2004, 10:12 AM
astroracer's Avatar
astroracer astroracer is offline
Don't run the pump dry... It'll burn up and cause more headaches then getting a shorter belt. Looping the system into a resevoir isn't safe either because of the high output side pressure. You would be farther ahead to get a power box and put it on while changing motors.
Mark
