350 chevy rocker adjustment - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-29-2008, 09:03 PM
I'm replacing my stock rockers with rollers and need to know how to adjust them. I'm used to the screw and locking nut type but am at a loss as to this type of procedure.
Old 02-29-2008, 09:16 PM
Solid or Hyd. cam? I have done it this way on my race engines for years, adjust the intake when the exhaust starts to open and do the exhaust when the intake starts to close. If you have a solid use your feeler gauge if it is a hyd. take all of the slack out of the pushrod and give it 1/4 turn then snug the jam nut down. Do not over tighten the jam nut.
Hope this helps, Mike
Old 03-01-2008, 02:21 PM
T-bucket23's Avatar
Wiki Edits: 26
If you are talking about how to tighten the poly lock nuts, the recomended procedure and one I have always used is basically adjust to 0 lash with the big nut , turn the inside lock down until it hits and turn them both together for the last 1/4 turn. I have used this procedure and never had one back off.
This is for Hydraulic only solids would be similar but you would adjust to the final lash, back of 1/4 lock the internal down and tighten both together for 1/4 back to the final lash setting
Chet
Hi. just wondering why the 350 chevy small block is so good... judgedredd Hotrodders' Lounge 78 06-25-2010 08:01 AM
350 chevy help joesnova2 Engine 7 11-08-2009 05:46 AM
buick 350 - chevy 350 72buick Engine 23 10-13-2009 08:38 PM
El Camino Engine - 350 Chevy or 455 Pontiac bjam2 Engine 16 08-07-2007 03:45 PM
chevy 350, tightening valve rocker arms Gladis Engine 6 02-28-2007 11:39 PM
