350 hp is easy. Have a good stock rebuild done with these upgrades. Flat top Hyper-eutectic pistons, Moly rings, Double roller t-set, a good mid range power hydraulic cam, M55a oil pump, steel sleeve oil pump drive (for reliability).
Then you get to the heads. Have a good three angle valve job done, you will usually need guides, so go with the bronze, use premium seals and Z/28 or better valve springs, mill the heads .010. Add a good Performer type intake, a set of headers and a 650-750 vac secondary carb and you will have a reliable powerful engine. Shop wisely and don't get hung up on brand names, do as much labor as you (and some Knowledgeable buddies) can and you can do all this within a budget. |
I dont see 350 N/A horsepower with flat tops, unless your possibly using 58cc heads to get the compression up closer to 10:1...maybe 64cc heads... but either way. your also going to need more than a Performer intake.The Performer is good to 5500 RPMs, your gonna need more RPM than that Id consider the Performer RPM, or Weiand Stealth.
Depending on what heads you have, itll take more than just a 3 angle valve job, by the time your done spending money on 2.02/1.60 valves & porting, might be better off with aftermarket heads. |
the Vortec heads are nice, theyll raise your compression to around 9.5:1 with flat tops, they flow great without major work.... but, they do need better springs, need machine work for higher lifts, also require a vortec style intake, rocker arms & valve covers...by the time your done with all that, might be better off buying a set of Sportsman IIs. a real good head for the money
if using the Sportsmans, get the 64cc & use a forged flat top piston that will give you about 9.5:1 with that head.
If your looking for 350 HP. your gonna have to have a pretty healthy cam, something that will run in the 6200-6500 range, unless you go with a hyd. roller , but that may be out of you budget. Dont forget, an engine like this is also going to need a loose convertor & is really going to want a gear a little steeper than what you might have. John |
What cam would u suggest and what about intake and carb
and also i have a th350 transmission with a B&M shifkit do u think this will withstand the added horsepower plus i want to add a stall conveter Last edited by 350MC; 06-14-2004 at 10:03 PM. |
This is a motor built like BOBCRMAN is saying. The only difference being the use of SR heads instead of reworked stockers.
http://www.compcams.com/Technical/Dy...62H-10_001.asp 348Hp @ 5300RPM.........And a Performer intake...........Dan |
boring an engine isnt a big power maker....unless the cylinders are worn & the engine is down on power anyway..030 over on a 350 is 5 cubic inches...so on a healthy street 350 that makes 1 hp per CI...thats a whole 5 HP. John
i thought an increase in bore gave more power than that i guess i learned sumthin new... so really if the engine seemed to run healthy and the cylinder walls look good getting the engine bored over is worthless?
