350 Chevy squeaks after rebuild - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2008, 12:37 PM
Team Revolution
Well, I rebuilt a 350 chevy about 3 weeks ago. I got it broke in and running pretty good. So one day when I was out drving around I thought i would stop and see if the ol' girl would spin the tires. Well, it did, and it did it good. But now after I did that, it has had this terrible squeek coming from the engine. Its not the water pump or any of the pullies because I took the belts off to see if it would still do it. The engine still has good oil pressure, so I dont think its the bearings, but it still might be? I just dont know what else to do. Any ideas?
Thanks in advace,
Logan
Old 05-24-2008, 12:38 PM
Team Revolution
Oh, and it doesnt do it all the time, It could be ideling just fine, then all of a sudden it will start. And it doesnt seem to do it after about 1200 RPM.
Old 05-24-2008, 01:32 PM
techinspector1's Avatar
Wiki Edits: 326
Just a shot in the dark. Check the flexplate for a crack.
The only time I ever heard an engine squeak, it was bearings.....
Old 05-24-2008, 02:01 PM
King of my Man-cave.
Me too.
tom
Old 05-24-2008, 03:54 PM
Wiki Edits: 326
Now that you guys mention it, my old 91 Ford 6-banger squeaked on start-up. Oil pressure was low, so I tore it down for a rebuild. I guess I just never put 2 and 2 together to identify the squeak and passed it off as the belts. Bearings were toast. Just fired it Wednesday night. No squeak.
Old 05-24-2008, 04:19 PM
junior stocker's Avatar
engine squeek
Stock stamped steel valve covers? There is actually a right and wrong way to install them; incorrecty and the rocker arms will contact/squeek. Look at them from the "front" and you'll see a difference. Just a thought.
That was a good point about the "early" staggered bolt valve covers, you could'nt put them on wrong.
Old 05-24-2008, 04:28 PM
Jmark's Avatar
Is it an automatic? My sons 400 started squeeking bad after we got it done. We searched and searced and finally unbolted the converter, no more squeek. Come to find out the torrington bearing in the converter went south cause they set it up too tight.
El Camino Engine - 350 Chevy or 455 Pontiac bjam2 Engine 16 08-07-2007 03:45 PM
My first Rebuild (350) dsgb610 Engine 3 06-25-2006 05:07 PM
Chevy 350 rebuild leegsr Engine 3 02-08-2006 05:29 AM
Buick 350 or Chevy 350 72Skylark Engine 21 02-02-2006 02:10 PM
information on rebuild of 471/671 blower for 350 chevy 37 chevy Engine 4 03-20-2003 12:05 PM
