#350 Chevy Starter - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-24-2012, 07:14 AM
Bobs36ford's Avatar
Last journal entry: Video of new upholstery
#350 Chevy Starter
Hi
I'm changing the starter on my Chevy small block 5.7 engine.
My question is should i get the mini or stock.
Bob
Old 02-24-2012, 07:57 AM
engineczar's Avatar
It depends on if you're having clearance issues between the starter and your headers or exhaust pipe. Some cars with tight engine bays and headers don't leave much room for a full size starter. The other problem that some people have is heat soak from the starter being too close to the headers or exhaust. Other than that if a standard size starter is getting the job done then going to a mini starter isn't a necessity.
BSE Racing Engines
Old 02-24-2012, 10:15 AM
Bobs36ford's Avatar
Starter
Thanks for the info.....I am having a clearance problem because i believe the starter i have on now is heat soaked. The engine only has 7000 miles and starter should be good.
Thanks again
Bob
350 Chevy starter Bobs36ford Electrical 13 02-09-2012 07:48 PM
Chevy 4.3 V6 starter on a 350.. RickyDoors Engine 5 11-23-2010 01:02 PM
Starter shifting and grinding.. new starter? Where does starter brace go? 84Z Engine 8 11-12-2007 02:44 PM
72 chevy starter skbackdoc Engine 9 10-31-2004 06:03 PM
72 Chevy starter.... nqcs Electrical 6 03-16-2004 04:19 PM
