350 Chevy Starting question
Ok Guys I'm stumped and I need help. I have a 350 chevy and I am having a really hard time with this starter issue. Ok I had to replace the old starter because it malfunctioned and kept cranking the car over even with the ignition switch off, so I had to replace the starter. Ever since then, I can't get the starter to work correctly.
When you first put the starter up, everything works fine. But when you let off and try to reengage the starter, it will catch for like a second or two and then start grinding. Then it will never really catch well enough to start the motor again.
I have checked the flywheel all the way around and there is no teeth missing or even marked in any way. I also looked at the starter bendex and there is no marks or signs of bad teeth on it either.
I also went out and bought a package of shims to try on the starter. There were three in the package. One .20, one .40 and one .60. I tried one at a time by themselves and that didn't help either.
No here's the really weird thing. If you unbolt the starter and take it down, then rebolt it back up, it will work once until you let off the key, then your done. But if you take the bolts out again and rebolt it up changing absolutely nothing it will work again until you let off the key. Any ideas?
Also the battery is brand new and fully charged. When the thing does turn over, it's turning it pretty fast so no problems there.
